[Warning] Omakase Lock!!
Thảo luận trong 'JMP: Tin Tức, Đánh Giá' bắt đầu bởi justiceman, 26 Tháng tư 2009.
  1. justiceman Thành viên
    Tình hình là sau khi đọc được topic của bác DavidRain và 1 bạn trên GSM có cai N905i cũng bị như bác David, em đã lên trang chủ docomo và tham khảo 1 vài web thì tìm được thông tin như này:
    Omakase Lock locks all key operations except for receiving incoming voice and Videophone calls and turning power on and off, and it disables functions such as IC card functions. (Will not be unlocked by turning off power.)
    [​IMG]If the handset compatible with this service is a GPS-compatible handset, location information services that use GPS such as Keitai-Oasgashi Service or imadoco search from My docomo can be used even when Omakase Lock is activated. Suspension operations can also be made while location information is being provided.
    Omakase Lock will lock the handset that contains the FOMA Card for your subscription. It will not lock the FOMA Card and external memory (SD cards, etc.).
    • [​IMG]Omakase Lock is not available in situations such as if the handset is outside the service area or the power is turned off, or when using mova with Dual Network Service.
    • [​IMG]Forced locking with Omakase Lock can be done even when other functions are operating.
    • [​IMG]Omakase Lock is a locking service activated by a request by the subscriber. Please note that if the subscriber and FOMA handset user are not the same, the subscriber may request the handset be locked without the consent of the user.
    • [​IMG]Application made at the same time as application for service suspension or during service suspension is free. However, charges will incur for application for Omakase Lock alone.
    • [​IMG]Charges will incur for Omakase Lock if service has been suspended due to non-payment of overdue charges, even if Omakase Lock application is made while service is suspended.
    • [​IMG]Please contact the docomo Information Center (0120-005-250) if you cannot deactivate Omakase Lock.
    Link:
    http://www.nttdocomo.co.jp/english/service/anshin/lock/
    Sau khi tham khảo thì em được tìm được 2 cách:
    Cách 1: liên lạc docomo theo số dt trên
    Cách 2: vào trang
    http://www.mydocomo.com/
    bằng 1 em JMP đăng kí 1 ID roài sau đó làm theo hướng dẫn (tới chỗ này hok có text mà toàn hình ảnh nên em ứ dùng google translate dc)
    Omakase lock là 1 dịch vụ của Docomo để thuê báo khóa dt của mình sau khi bị mất hoặc để quên đâu đó. Khi bị lock vẫn có thể nhận dc cuộc gọi
  2. duy009
    vấn đề này xảy ra lâu rồi bạn, và DavidRain ko phải trường hợp đầu tiên,từng thấy 1 máy SH905iTV,1 máy SH903iTV,SH906iTV....đã bị IC-lock....thank bạn đã có công tìm kiếm giúp anh em
  3. DavidRain
    DavidRain Thành viên
    Toàn tiếng Nhật thế này thì chịu rùi
    Cám ơn bạn rất nhiều, liên lạc với Docomo thì quả thực khó
    Cách thứ 2 thì khả quan hơn, mình sẽ cố gắng nhờ bạn dịch giùm để giải quyết dứt điểm vấn đê này cho anh em box sharp nói chung và các vợ mình nói riêng
  4. Japan Mobile !
    Japan Mobile ! Thành viên
    Cảm ơn bác đã cảnh báo, vậy là lỗi này các máy cũ có nguy cơ bị cao
  5. buiqtrung
    buiqtrung Ex-Mod
    nguy cơ chỉ xẩy ra khi mấy ông trộm máy mà vẫn bật máy lên khi có sim khổ chủ ở trỏng(roamming cũng dính)...còn không thì có 10 Docomo cũng ko thể làm được
    khangduybeo thích bài này.
  6. aloalo000
    aloalo000 Thành viên
    nếu tìm mấy ông sếp người nhật ở đây nhờ ổng bỏ sim của ông vào gọi cho docomo thì mở dc ko các bác nhỉ
  7. aclatinh
    aclatinh Thành viên
    đã ai unlock được Omakase lock chưa, em có con máy NTT Docomo N906i cũng bị thế này nên không sao sử dụng được.
  8. aloalo000
    tình hình vẫn là tình hình,ai tim ra thuốc giải chưa cứu em nó vơi
  9. thanhxevodoi
    thanhxevodoi Thành viên
    em hok hỉu,màn hình của con 906itv của em có chữ IC Lock mà vẫn xài bình thường??nge gọi bình thường
  10. vampirebat
    vampirebat Thành viên
    ko phải IC lock, mà rõ chữ OMAKASE LOCK ACTIVITED. David nói đúng đấy ,chỉ có máy lấy cắp , đang dùng SIM của chủ mới bị. thằng em tôi vớ được con máy docomo L01A ở đâu đó, gọi thoải mái (SIM của người Nhật nào đó) sau 1 thời gian có cô gái Nhật nào đó gọi đến, chắc để hỏi ''sao cầm máy em?''.Sau đó bị lock, bật máy lên chỉ có chữ OMAKASE LOCK ACTIVITED, ko bấm được phim nào.Chắc ra shop docomo la ok (mượn SIM người khác )
