Công ty TNHH TMDV Nguyên Phong 162 Ngô Quyền - P. 5 - Q. 10 - TP.HCM ( Ngã tư Ngô Quyền-Vĩnh Viễn, khu vực chợ điện tử Nhật Tảo ) Mr Quân 0933.204.588 - 0987.367.163 Nick yahoo: hcm_quanpm ( Giao hàng tận nơi ) TK ĐÔNG Á BANK (CHI NHÁNH TÂN BÌNH) - 0105063505 - PHẠM MINH QUÂN Buffalo AirStation WHR-G300N (AirStation™ Nfiniti™ Wireless-N Router & Access Point WHR-G300N) http://www.buffalotech.com/products/...int-whr-g300n/ Hàng New 100%, fullbox,giá: 499,000VND bảo hành 3 tháng, 1 đổi 1 Wireless - Designed to IEEE802.11n Draft 2.0 Specifications - Wireless Connections up to 300Mbps* Security - Easy Setup with AirStation One-Touch Secure System(AOSS) - Supports WPA2-PSK (AES), WPA-PSK (TKIP,AES), and 128/64-bit WEP Security - Includes NAT/SPI Firewall and lntrusion Detector Convenience - Simple Web Browser Configuration - Includes External Button to Switch Between Router or Access Point Modes - Built-in DHCP Server - Built-in 4-port 10/100 Auto-Sensing Switch -------------------------------------------------------------------------- Buffalo AirStation WHR-G300N V2(VERSION 2) (AirStation™ Nfiniti™ Wireless-N Router & Access Point WHR-G300N V2) Với dòng sản phẩm này, tính ổn định rất cao, công suất lớn. Đặc biệt chức năng repeater ( thu & phát sóng ) cực mạnh Hàng New 100%, fullbox,giá: 699,000VND bảo hành 3 tháng, 1 đổi 1 Wireless - Designed to IEEE802.11n Draft 2.0 Specifications - Wireless Connections up to 300Mbps* Security - Easy Setup with AirStation One-Touch Secure System(AOSS) - Supports WPA2-PSK (AES), WPA-PSK (TKIP,AES), and 128/64-bit WEP Security - Includes NAT/SPI Firewall and lntrusion Detector Convenience - Simple Web Browser Configuration - Includes External Button to Switch Between Router or Access Point Modes - Built-in DHCP Server - Built-in 4-port 10/100 Auto-Sensing Switch -------------------------------------------------------------------------- WZR-HP-G300NH ( AirStation™ Nfiniti™ Wireless-N High Power Router & Access Point WZR-HP-G300NH ) http://www.buffalotech.com/products/...wzr-hp-g300nh/ Hàng New 100%, fullbox. Giá: 999,000VNĐ, Bảo hành 3 tháng, 1 đổi 1 - Dòng đặc biệt Highpower N hỗ trợ công suất phát cực mạnh lên đến 800mW, đặc biệt tích hợp cổng USB sử dụng truyền dữ liệu, xem phim HD, sử dụng NAS. Kết hợp cùng với port LAN 1Gb tặng cường khả năng truyền dữ liệu. -------------------------------------------------------------------------- WBMR-G54 ( Wireless ADSL 2+ Router) Hàng nguyên seal, fullbox. Giá: 599,000VNĐ- Bảo hành 3 tháng, 1 đổi 1 Tích hợp WLAN 802.11g tốc độ lên đến 54Mbps Cấu hình trình duyệt Web đơn giản Tốc độ cao Kết nối với băng thông download lên đến 24Mbps và upload 1Mbps SPI Firewall Bảo vệ và tấn công DoS Phòng Tích hợp DHCP Server Tự động Senses Connection Type Bốn Ports lan 10/100 Ports cho đến 4 thiết bị đồng thời có dây Hỗ trợ Traffic Shaping QoS, IGMP Snooping Multicast và 4 hàng đợi ưu tiên cho người sử dụng -------------------------------------------------------------------------- Buffalo WBMR-G125 AirStation ADSL 2+ Wireless Router Hàng New 100%, fullbox,Giá: 499,000VNĐ,Bảo hành 3 tháng,1 đổi 1 Tích hợp WLAN 802.11g tốc độ lên đến 125Mbps Cấu hình trình duyệt Web đơn giản Tốc độ cao Kết nối với băng thông download lên đến 24Mbps và upload 1Mbps SPI Firewall Bảo vệ và tấn công DoS Phòng Tích hợp DHCP Server Tự động Senses Connection Type Bốn Ports lan 10/100 cho đến 4 thiết bị đồng thời có dây WBMR-G300N (Wireless-N Nfiniti™ Broadband ADSL2+ Modem Router) Hàng nguyên seal, fullbox. Giá: 899,000VNĐ- Bảo hành 3 tháng, 1 đổi 1 Modem WBMR-G300N là một ADSL 2+ không dây.Nó có bốn cổng lan 10/100 Base-T Ethernet và cung cấp WAN với băng thông lên đến 24Mbps. AP tích hợp tuân thủ IEEE 802.11n (Draft 2.0) tiêu chuẩn, cung cấp tốc độ đường truyền không dây lên tới 300Mbps. router hỗ trợ WEP và WPA/ WPA2 không dây mã hóa và 802.1x chứng thực. Modem WBMR-G300N cung cấp VPN pass-qua cho IPSec, L2TP và PPTP. Nó có tính năng tích hợp SPI tường lửa để bảo vệ mạng từ chối dịch vụ (DoS) tấn công. WHR-HP-G54: AirStation™ Wireless-G High Power Router & Access Point http://www.buffalotech.com/products/...nt-whr-hp-g54/ Đặc biệt với chức năng thu & phát sóng wifi cực mạnh Hàng new 100%, fullbox,Giá: 649,000 VNĐ, Bảo hành 3 tháng, 1 đổi 1 WHR-HP-G54 có công nghệ High Power cho phép khuếch đại tín hiệu để đạt tốc độ, khoảng cách cao hơn nhiều lần router chuẩn 11g khác. Quá trình cài đặt rất nhanh chóng và dễ dàng với kỹ thuật SmartRouter của AirStation. Router tự động phát hiện kết nối Internet và chỉ hỏi bạn những thông tin thật cần thiết trong quá trình thiết lập kết nối. Giao diện thiết kế rất thuận tiện và tại trang đầu tiên trong giao diện, bạn có thể cấu hình "port mapping" cho trò chơi mạng (Internet game), tường lửa, cài đặt mã hóa, cập nhật firmware, kiểm tra kết nối WAN, kích hoạt chức năng AOSS... Bên cạnh khả năng mã hóa Wi-Fi cao cấp, router còn có các chức năng bảo vệ như tường lửa phòng chống tấn công, hạn chế kết nối Internet bằng cách lọc địa chỉ MAC. Chức năng phát hiện tấn công có thể gửi cảnh báo qua e-mail hoặc hộp thoại "pop-up" đến máy tính chỉ định. Chức năng lọc IP cho phép lọc gói tin trao đổi giữa WAN với LAN. Chức năng WDS cho phép mở rộng hệ thống bằng cách lắp thêm nhiều router theo dạng bắc cầu. Thử nghiệm tại Test Lab cho thấy WHR-HP-G54 cho kết nối cực "bền": không đứt kết nối trong suốt quá trình thử nghiệm và lập kỷ lục mới về tốc độ (bảng so sánh kết quả). Thử nghiệm Buffalo High Power WHR-HP-G54 với card cardBus WLI-CB-G54S dành cho máy tính xách tay cho thấy kết nối ổn định, tốc độ cao vượt trội trong khoảng cách ngắn; nhưng tốc độ trung bình cách biệt giữa các thời điểm - Đặc biệt với dòng này đã được up lên Firmware đặc biệt chuyên dùng để làm cầu nối cực mạnh, theo nghĩa thông thường là thu sóng wifi và phát ngược lại bằng Lan và wifi. Với tính năng cao cấp của dòng High Power kết hợp với Firmware chuyên dùng, làm tăng tính năng sử dụng của dòng WHR-HP-G54 cao cấp hơn -------------------------------------------------------------------------- WCR-GN:Wireless-N150 Router & Access Point Hàng New 100%, fullbox,Giá: 549,000VNĐ – Bảo hành 3 tháng, 1 đổi 1 The AirStation N-Technology Wireless-N150 Router & Access Point WCR-GN is a compact, entry-level wired and wireless solution, combining Buffalo’s legendary wireless technology with a simple and hasslefree installation. Buffalo’s AirStation One-Touch Secure System (AOSS™) and Wi-Fi Protected Setup (WPS) allow you to easily configure security settings and connect to the Internet in a matter of minutes. With speeds up to 150 Mbps, N-Technology provides performance and range superior to that of 802.11g wireless products. The Wireless-N150 Router & Access Point is a high value wireless router that is compact and easy to use. -------------------------------------------------------------------------- WCR-G54: Wireless-G Broadband Router & Access Point Hàng New 100%, fullbox. Giá: 399,000VNĐ- Bảo hành 3 tháng, 1 đổi 1 AirStation™ HighPower ADSL+ Modem Router WBMR-HP-GN Hàng new fullbox - BH 3 tháng 1 đổi 1- Giá 649.000 VNĐ Modem Router AirStation ™ HighPower WBMR-HP-GN ADSL 2+ sử dụng không dây mới nhất để cung cấp kết nối Internet tốc độ cao lên tới 150Mbps, 3x nhanh hơn so với Wireless-G. Các Modem Router kết hợp xây dựng trong 100Mbps 4-Port Router, Một tích hợp ADSL Modem và rất dễ dàng để thiết lập với Buffalo AirStation ™ One-Touch Secure System (AOSS ™). Đặc điểm nổi bật: • HighPower Công nghệ để tăng phạm vi để loại bỏ các điểm chết • tốc độ cao ADSL2 + Kết nối với Giá đường lên đến 24Mbps Hạ lưu và 1Mbps Thượng nguồn • Hỗ trợ WPA2, WPA-PSK (TKIP, AES) Và 128/64-bit WEP An ninh Buffalo AirStation WZR2-G300N Hàng New 100%, fullbox, Giá: 699,000 VNĐ - Bảo hành 3 tháng, 1 đổi 1 BOX LinkStation Live™ LS-CHL Hàng new - BH 1 tháng 1 đổi 1- Giá 600.000 VNĐ Buffalo LS-CHL là cách đáng tin cậy để liên tục lưu trữ và chia sẻ dữ liệu của bạn ở một vị trí, có thể truy cập bởi bất kỳ PC hoặc Mac vào mạng của bạn. Chia sẻ với mọi người ở nhà và thậm chí với bạn bè và gia đình qua Internet với Web Access. Dễ dàng chuyển nhạc và phim yêu thích của bạn từ LinkStation Live của bạn trực tiếp với PC, Mac, hoặc DLNA máy nghe nhạc phương tiện truyền thông ở trung tâm giải trí gia đình của bạn. LS-CHL thân thiện với người dùng ,làm cho việc chia sẻ đơn giản. Với Buffalo của Web Access, bạn có thể tải các tập tin, hình ảnh , nghe nhạc và phim ảnh, và thậm chí tải dữ liệu lên LinkStation Live của bạn - bất cứ lúc nào, bất cứ nơi nào trên Internet. Bạn thậm chí có thể truy cập tài liệu của bạn và thư viện truyền thông kỹ thuật số với iPhone của bạn! LS-CHL bao gồm một built-in USB Print Server để chia sẻ một máy in với các máy tính trong nhà bạn. Ngoài ra, cổng USB có thể được sử dụng để mở rộng dung lượng lưu trữ hoặc sao lưu trực tiếp bằng cách gắn một ổ cứng USB 2.0 vào mặt sau của thiết bị. AirStation™ Nfiniti™ Wireless-N Compact USB 2.0 Adapter WLI-UC-G300N Hàng new fullbox - Giá 250,000 VNĐ - BH 1 tháng 1 đổi 1 Các dòng còn Fullbox: WCR - GN, WBMR-HP-GN, WHR-G300N, WHR-G300N V2, WBMR-G300N, WBMR-G54, WCR-G54 CHI TIẾT VUI LÒNG LIÊN HỆ: Công ty TNHH TMDV Nguyên Phong MR QUÂN ( 0933.204.588 - 0987.367.163)
