WiFi File Explorer PRO 1.6.1 - quản lý file trên điện thoại bằng PC qua Wifi
Thảo luận trong 'Android: Ứng Dụng' bắt đầu bởi Khỉ Con, 9 Tháng bảy 2011.
  1. Khỉ Con interista
    WiFi File Explorer PRO ​
    Yêu cầu: Android 1.6+
    Tính năng: Tìm kiếm, download, upload, xóa, sao chép file trong chiếc Android của bạn mà không cần cắm cable vào vi tính hay tháo thẻ nhớ ra. Mọi thứ được thực hiện thông qua sóng Wifi.
    [​IMG][​IMG][​IMG]
    Browse, download, upload, delete, copy, ZIP, stream and manage files via WiFi!!
    * Featured on Life Hacker and recommended by Motorola! Best and cheapest! *
    Browse, transfer, download, upload, delete, copy, rename, stream and manage files that are on your Android device, using a web browser via a WiFi connection.
    No more taking your phone apart to get the SD card out or grabbing your cable to access your camera pics or copy across your fave MP3s.
    "I wholeheartedly recommend going the wireless route with WiFi File Explorer!" - PC World review - 5 stars.
    FEATURES
    1. Using a web browser, you can browse, download and manage all the files on your Android device without the need for a cable;
    2. Multiple batch file uploads and downloads to save you time when transferring many files at once;
    3. Download entire directories on your Android device with just one simple click – for example, backup all your photos just by downloading the Camera directory;
    4. Select all the directories on your Android device and do a multiple download to backup your entire SD card!
    5. Download a streaming media playlist to allow you to quickly flick through and stream all the stored media files in a directory;
    6. Create brand new directories and delete/rename/copy/zip/unzip files - the perfect file manager;
    7. Have any application files stored on your Android device? WiFi File Explorer is also an installer, so automatically install them with just once click in the web browser;
    8. Stream individual music and video files from your Android device straight to a web browser;
    9. View all the camera pictures and videos on your Android device directly in a web browser;
    10. Simple to use with no set up or buttons – it just works!
    11. Password protected;
    12. Ability to configure the port settings;
    13. Full support for special characters;
    14. Send an email to the web link from the app for easy connection;
    15. LOTS more features in development;
    Thông tin chi tiết:
    [URL="https://market.android.com/details?id=com.dooblou.WiFiFileExplorerPRO"]https://market.android.com/details?id=com.dooblou.WiFiFileExplorerPRO[/URL]
    Tải về:
    http://appstore.vn/a/index.php/home/app/554
    tdvcb44 and vodka1908 like this.
  2. Khỉ Con
    Cập nhật 1.3.8
    What's new in version 1.3.8
    Fixed the "Filename" bug
    Added Polish support
    Included secret "Development Goodies" settings
    Tap on the title in the app 3 times to unlock them in Settings
    Try out SSL and Access Point Mode
  3. Khỉ Con
    Cập nhật
    What's in this version:
    1.4.2
    App will now work when in Portable WiFi Hotspot Mode
    Improved license validation
    Some changes to localization
    1.4.0
    New web UI layout
    Thumbnails view
    Modes
    Search mode
    Logout option
    Breadcrumb
    Persisting view after an action
    Faster load times
    ZIP files now compatible with Winzip and 7zip
    Exit reminider
    Battery bar
    WiFi Singnal Strength bar
    Internal and external storage bars
    Link to more apps by dooblou
    Prevent missing images in IE9
    Fix invalid HTML
  4. Khỉ Con
    Cập nhật 1.4.3 !!!!!!!!!!!!
  5. Khỉ Con
    1.6.1
    1. Improve layout for multiple screen sizes
  6. hungtt7
    hungtt7 Thành viên
    Đây là phần mềm có trả tiền, lấy đâu ra $ để mua đây.
  7. Khỉ Con
    Mọi phần mềm mình post đều đã được cr@cked, dùng free nhé ;)
