Yêu cầu phiên bản Android từ: 2.1 Ảnh chụp màn hình: Thông tin chi tiết: Set your wallpaper to an always updated realistic view of the Earth.Sets your wallpaper to a realistic image of the Earth with real-time display of clouds, nighttime city lights, local time, and more. View the world as a map or globe, follow the sunrise or sunset, or scroll to any location by double-tapping the home screen. By downloading this app, you agree to the EULA at http://rev-zero.com/eula/worldview INSTRUCTIONS: This is a live wallpaper, so it doesn't show up in the regular application drawer. To use, long press on the home screen, tap "Wallpapers" then "Live wallpapers", scroll to and tap "WorldView", optionally customize using "Settings...", then tap "Set wallpaper". If you are using Globe View, or Map View without a tracking mode configured, you can double-tap the home screen to scroll to and stop at the desired central location. Features planned for upcoming version 2.0: - Zoom level for map view - 3D rotating, zoomable globe Xem thêm trên Android Market: Mã: [URL]https://market.android.com/details?id=com.rev_zero.worldview&feature=search_result[/URL] Tải về: Mã: [URL]http://appstore.vn/a/index.php/home/app/500[/URL]
1.3.11 What's in this version: 1.3.11: Maintain scroll location for Globe View image across image updates Add preference setting to center the image on the left screen rather than the middle one (for some Samsung devices)
