Xchanger v1.12 S60v3/v5 SymbianOS9.x Signed Xchanger is a currency converter, with auto-update feature and really simple user interface. And best of all, it is FREE!!! Features: * Auto-update * Convert between 150+ currencies including Gold, Silver, Palladium, and Platinum price * Simple user interface * Easy to use * FREE Change Log : - Close the active connection after updating rates is completed if "Auto-update" feature is not set (e.g. "Update timer" setting is set to "Never").
Xchanger v1.14 S60v3/v5 -currency converter with Auto Update feature-(Upd:31.05.10) Xchanger is a currency converter, with auto-update feature and really simple user interface. And best of all, it is FREE!!! Features: * Auto-update * Convert between 150+ currencies including Gold, Silver, Palladium, and Platinum price * Simple user interface * Easy to use * FREE Change Log : - Add new menu "Conversion > Delete all", use it to delete all conversion from the list. - Now adding new conversion more easier using "Add new conversion" from the list, no need to go to the "Options > Conversion > Add" - Fix some user interface minor issue with touchscreen devices (S60 5th devices).
Xchanger v1.23 S60v3/v5 SymbianOS9.x Signed Xchanger is a currency converter, with auto-update feature and really simple user interface. And best of all, it is FREE!!! Features: * Auto-update * Convert between 150+ currencies including Gold, Silver, Palladium, and Platinum price * Simple user interface * Easy to use * FREE
