Các bạn chỉ giúp mình đóng gói file phone.apk với Lúc mình giải nén phone.apk thì nó thế này Đang giải mã file APK... I: Loading resource table... I: Loaded. I: Decoding AndroidManifest.xml with resources... I: Loading resource table from file: C:\Documents and Settings\Garena\apktool\framework\1.apk I: Loaded. I: Regular manifest package... I: Decoding file-resources... W: Could not decode attr value, using undecoded value instead: ns=android, name=textAppearance, value=0x0207000d W: Could not decode attr value, using undecoded value instead: ns=android, name=textAppearance, value=0x0207000d W: Could not decode attr value, using undecoded value instead: ns=android, name=textAppearance, value=0x0207000d W: Could not decode attr value, using undecoded value instead: ns=android, name=textColor, value=0x0205009a W: Could not decode attr value, using undecoded value instead: ns=android, name=textAppearance, value=0x0207000e W: Could not decode attr value, using undecoded value instead: ns=android, name=textAppearance, value=0x0207000f W: Could not decode attr value, using undecoded value instead: ns=android, name=textAppearance, value=0x0207000f W: Could not decode attr value, using undecoded value instead: ns=android, name=textAppearance, value=0x0207000d W: Could not decode attr value, using undecoded value instead: ns=android, name=textColor, value=0x0205009a W: Could not decode attr value, using undecoded value instead: ns=android, name=textAppearance, value=0x0207000d I: Decoding values */* XMLs... I: Done. Can't find framework resources for package of id: 2. You must install proper framework files, see project website for more info. ---------------- XONG ---------------- Mình dùng phần mềm SuperApkToolv2.1 và 1 sồ phần mềm khác để đóng gói file phone.apk mà vẫn cứ báo lỗi Đang đóng gói file APK... Exception in thread "main" brut.androlib.AndrolibException: brut.directory.PathNotExist: apktool.yml at brut.androlib.Androlib.readMetaFile(Androlib.java:164) at brut.androlib.Androlib.build(Androlib.java:183) at brut.androlib.Androlib.build(Androlib.java:176) at brut.apktool.Main.cmdBuild(Main.java:218) at brut.apktool.Main.main(Main.java:74) Caused by: brut.directory.PathNotExist: apktool.yml at brut.directory.AbstractDirectory.getFileInput(AbstractDirectory.java:103) at brut.androlib.Androlib.readMetaFile(Androlib.java:160) ... 4 more Như vậy có nghĩa là lỗi gì ạ? mình đã thử chỉ giải nén ra và không làm gì cả, mà đóng gói lại nó cứ như vậy, chán quá... Có bạn nào giúp mình với đc không? Mình dùng Apktool nó cũng báo thế Hay là do máy còn cài thiếu cái gì phải không ạ? File phone.apk này là rom của máy ss m110s 4.1.1 Mình đang dùng PC ASUS
