FExplorer Pro
Thảo luận trong 'ỨNG DỤNG HỆ THỐNG' bắt đầu bởi dung1291985, 23 Tháng năm 2009.
  1. tichau
    tichau Guest
    Cái này tương lai chắc cũng bán license hay sao mà cũng có vụ đếm lùi 3 giây y chang X-plore luôn.Chán chẳng muốn xài :)).
  2. tichau
    tichau Guest
    FExplorer Pro v2.0 Beta3
    FExplorer Pro Overview
    FExplorer Pro is a utility suite for S60 phones. The main feature is of course the astonishing file browser alongside various tools and options that you can use to better manage your phone in general.
    File Browser
    The file browser is very very extensive and is what made FExplorer so popular to begin with!
    It includes everything you will ever need from a file browser similar to Windows File Explorer or Total Commander (for Desktop).
    Features include (but are not limited to):
    • Searching for files on your phone.
    • Creation/Renaming/Deletion of files and folders.
    • Enter folders that can't be seen on the Nokia phone browser.
    • Three types of file editors (Hex, Binary and Text)
    • Attributes changes on files.
    • Zip(!)
    • Image viewer
    Tools
    With these tools, you can have a lot of your favorite tools all in one place, and it replaces the need to use other 3rd party applications for each of the functions (for instance Screenshot)
    a short overview of what each of these tools does:
    Screenshot - Similar to the Antony Pranata's Screenshot for S60, this tool allows you to create screenshots of your phone from anywhere on the phone with various options to handle file saving etc...
    Backlight - This will turn your e-mail notification light on/off similar to Best Torch for S60. Very handy as it can turn your phone into a flashlight when you most need it smile.gif
    Bluetooth manager - This is VERY handy also. It will turn your Bluetooth on/off with a click of a button.
    Compress memory - de-fragments memory. You receive the memory available before and after the call to the function too.
    Installed applications - more for developers - it generates a file (C:\INSTAPP.TXT) which contains all of the installed applications (by the application manager), their UID and their path.
    Dump file list - generates a file (C:\FILESLST.TXT) containing the list of the files and the directory starting at the current possition (current directory)
    Phone
    More options that you have for your phone in FExplorer Pro are shown above.
    Here is a short overview of what each function does:
    Phone info - this will give you all of the details that can be obtained about your phone like firmware version, IMEI etc...
    Restart - restarts the phone.
    Network info - gives you all available information that can be obtained about your network like area id, cell id, network name etc...
    Media info - gives you full stats on the installed memory card.
    What's the NEW:
    • the '5' to toggle tabs works now
    • new icons everywhere
    • in the settings, the save option from the menu doesn't crash; the options (left softkey) has now 'edit' and 'discard' and the right softkey performs a 'save' and 'back'
    • the zip supports from the menu doesn't return an 'only available in pro version'
    • the screenshot hot key is the 'C' key (backspace), the files are saved in \\images\\fe_img
    • in the screenshot, the toggle between phone memory or mmc (to save the files) has been fixed
    sc311 and ngoit06 like this.
  3. ngongocthuan
    ngongocthuan Thành viên
    Xin chào!
    Bản Pro này có mục Inbox không các bạn ơi?
  4. tichau
    tichau Guest
    FExplorer Pro v2.00 Final S60v3 S60v5 Symbian9.x Sigend
    What is FExplorer Pro
    FExplorer Pro (FEP) is a utility suite for S60 phones and supports 3rd and 5th edition phones. The main feature is of course the astonishing file browser alongside various tools and options that you can use to better manage your phone in general.
    File Browser
    The file browser is very very extensive to give you complete control over your phone's file system.
    It includes everything you will ever need from a file browser similar to windows File Explorer or Total Commander (for Desktop).
    * Searching for files on your phone.
    * Creation/Renaming/Deletion of files and folders.
    * Enter folders that can't be seen on the nokia phone browser.
    * Three types of file editors (Hex, Binary and Text)
    * Attributes changes on files.
    * Zip(!)
    * Image viewer
    And much, much more!
    You will only grasp the myriad of options and features in this quaint application once you really start using it on a regular basis.
    In addition to the file browser, there are two additional tabs in FExplorer Pro (which can be toggled on/off using the "5" key):
    Tools
    I will give a short overview of what each of these tools does:
    Screenshot- Similar to the Antony Pranata's Screenshot for S60, this tool allows you to create screenshots of your phone from anywhere on the phone with various options to handle file saving etc...
    Backlight - This will turn your e-mail notification light on/off similar to Best Torch for S60. Very handy as it can turn your phone into a flashlight whenyou most need it Posted Image
    Installed applications- more for developers - it generates a file (C:\INSTAPP.TXT) which contains all of the installed applications (by the application manager), their UID and their path.
    Dump file list -generates a file (C:\FILESLST.TXT) containing the list of the files and the directory starting at the current position (current directory)
    As I mentioned above, now that FExplorer Pro is modulated in this fashion,we will be adding more tools to this list as time passes, which will continuously enhance your FExplorer Pro Posted Image
    Phone
    note: Options register Don,t Work. press continue
    don,t expired
    duc2012 and ngoit06 like this.
  5. duc2012
    duc2012 Thành viên
    bác ơi bản này có bị uninstall ko đó??hic.xài mấy bản trước ko được
  6. tichau
    tichau Guest
    Bạn cứ cài vào máy.Nếu có lỗi gì thì cho biết cụ thể nhé.
  7. tttuyentinh
    tttuyentinh Thành viên
    cái ScreenShot xài ngon(*), không có Inbox hơi tức tức, cái này cũng được quá đi chứ, miễn là đừng còn 1..2..3... ;))
  8. lienhong75
    lienhong75 Thành viên
    mình cài vào con N86 mỗi lần mở nó điêu 1..2..3..
    làm cách nào cho hết ?
  9. tichau
    tichau Guest
    Đành chấp nhận chuyện đó thôi bạn :D.Muốn hết 1 2 3 thì mua license :-".
  10. tichau
    tichau Guest
    SBSH FExplorer Pro Final v2.00 S60v3 S60v5 Symbian9.x UnSiged-mEnPDA
    File Browser
    * Enter folders that can't be seen on the Nokia phone browser.
    * Zip(!)
    * Image viewer
    Tools
    Phone
    NOT NEED REGESTER
    tttuyentinh thích bài này.
